RP-AX56 disable LED?
shaun3000
Is there a way to disable the LED on the RP-AX56 extender? There doesn’t seem to be a setting in the web interface. I could resort to electrical tape but thought there might be a more elegant solution.
L&LD
Part of the Furniture
A black Sharpie (pen)?
A dab of black nail polish?
Hide the extender behind a poster/picture frame?
SteverinoLA
Check the Asus phone app. My 86U also has no way to disable LEDs in web interface, but sure enough, the option is there in the phone app.
Tech9
Your 86U, RT-AC or RT-AX version of it, has a physical button for LEDs on/off.
Tech9
RT-AC86U button is at the back, RT-AX86U button is on the side.
SteverinoLA
Ah, yes indeed! I never noticed that button before it's so well blended into side of unit.
And obviously, I did not bother to read any quick start guide or manual, lol.
Tech9
There are more physical buttons, if you haven't noticed yet. The Reset button is the one most often used. :)
Crimliar
There is no way to turn off the LED on the RP-AX56 extender, I have white electrical tape over the LED on mine!
*I always knew that white tape would come in useful for something someday!
