RT-AC88U Wireless dropping out
LeeTaylor44
Hi All,
My RT-AC88U was recently upgraded to f\w:3.0.0.4.384_81116
Since the upgrade wireless connectivity has been intermittently dropping out very 10 to 15 mins. Has anybody else experienced this?
Are you able to suggest which firmware to use for stability? I am also using 2 x RT-AC68U with the RT-AC88U in an AI MESH configuration. I have removed those devices temporarily , but the issue remains when running the AC88U on its own.
Thank you in advance for any help.
The most obvious thing to do is go back to the previously used firmware version and see if the problem disappears. If the problem is occurring every 10 to 15 minutes it will be very easy to test.
Hi All,
You could just ditch Assus firmware and try merlin firmware
Yes, it does. :)
