RT-AX88U Dual WAN Disconnected past 386.3.2 (or RT-AX88U_386.4_alpha2-ga85421da82)
scott420
Hi Team,
I thought I'd make my own thread for this.
I run a RT-AX88U using dual WAN load balance -one is a 100/10 fixed wireless, second is a 6/1 DSL. Set it 9/1 load balance, with some connections only going thru secondary (like my gaming laptop, since games have much less latency from the DSL as long as I don't overload the bandwidth).
Anything after RT-AX88U_386.4_alpha2-ga85421da82 I get disconnects and nothing I've tried works except downgrading to this version (It's a alpha, so I've gone to 386.3.2)
I've factory wiped this device - (not uploaded a CFG) - set up Wifi, DUAL WAN - works until a reboot - and then back to either one or both of WAN shows disconnected.
I've done the NVRAM trick Merlin posted - Beyond that in Network query I've tried DNS Query, PING, etc.
(on 386.3.2 I have it set as Ping Query on my hop 2 of my primary ISP, never had a problem) anything beyond it, goes to crap)
I would like to keep up with the upgrades, but it screws up my internet and that's not reasonable. I tried 386.5 beta - same issue as above and I've reverted to 386.3.2
Is there any information or anything I can do?
scott420
So I figured this out. I disabled IPV6 on the router.
I would like to have IPV6 available locally, but neither of my ISP's support IPV6 (Like I did in the suburbs when I bought this router and used cable internet).
Upgraded to 386.5.2 and then went to DNS query and both WAN's are showing connected.
scott420
Nope - rebooted the router and it went back to disconnected. I thought we got this fixed!
factory wiping and attempting to fresh setup.
scott420
What the heck is wrong? I’m back to this garbage disconnected. It works for one reboot.
John Fitzgerald
It’s all configured properly AGAIN - i pray it doesn’t crap the bed after a second reboot.
Try wiping the JFFS partition on next reboot, tick box & scroll down to hit apply, then reboot.
Admin > System >
Also try, 386.5_2 : https://onedrive.live.com/?authkey=!AJLLKAY--4EBqDo&id=CCE5625ED3599CE0!3051&cid=CCE5625ED3599CE0
You can also save settings > reset to factory default > then reapply your settings.
The jump to the newest should include the Reset, after the flash.
Assuming no add-on scripts, as none mentioned. (you can save that, like above)
scott420
I'm going to edit my reply - reformatting my JFFS - reinstalling diverson and scmerlin, re-upgrading to 386.5.2 has been solid so far. Pings are back to "normal".
So far.
Thank you.
