ReignOfComputer
Hi, I have an RT-AX88U AiMesh Router with an RT-AC88U connected as a Node. They are connected by Ethernet.
From the Web GUI, the RT-AC88U has:
Connection Priority: Ethernet
Connection type: Wired
Only the 2.4GHz LED is lighted on the RT-AC88U. The 5GHz LED is not lighted up.
2.4GHz devices connect fine to the AiMesh node, but all 5GHz devices connect to the RT-AX88U.
My working theory is that because the RT-AX88U broadcasts WiFi 6, the RT-AC88U isn't compatible and just doesn't broadcast at all. Any ideas would be appreciated, thanks!
