\Hello!
I have a strange issue. Every time I reboot my rt-n66u and after that I reboot my windows 7 machines, the "Set network location" dialog pops up in windows. Does anyone know why this appends?
(i'm running the latest Merlin build)
Did you set a static IP for your pc ?
In the case you did not set a static IP adress for the router please try to set one.
In my case the problem was with the DHCP server of the N66U, after setting a static ip the problem was gone.
Do you really need TAP? For most people TUN works just as well (and is actually less problematic).
TAP should only be used for cases where you really need to have your client computer act as if it was physically on the same LAN, so it can support broadcast-based applications (such as DHCP) for example.
no. the only reason I chose tap is because I got i to "work"
I did try to use tun but for some reason the vpn client could not reach the machines in my 192.168.2.0 net. I guess it has something to do with routing but since i got tap to work i did not digg into how routing works
Welcome To SNBForums
