VPN kill switch not activating on AX88U with Asuswrt-Merlin
copydeskcat
Hi guys,
I've read a few other threads about this and no-one seems to have an answer. I'm using an AX88U with Asuswrt-Merlin (388.1) and ProtonVPN profiles. The VPN Client and Director works a treat - I can route/direct traffic through any devices on my network via any of the VPN profiles, and they work fine.
However, if the VPN goes down for any reason, the connection persists - and reverts back to my home IP address, which I don't want to happen on a few of the devices. I'd rather the connection just died. I have Kill switch enabled, but it doesn't seem to make any difference.
Does anyone know if there's something else I should be (or could be) doing to make this work properly?
CDC
Ripshod
I've seen the many threads regarding this so I've just been testing. I disabled YazFi and let all my IoT devices obtain their IP via dhcp and tested with the app - all good. Then I set them all up in VPN director, waited for them to stabilise and stopped the remote server. Guess what? No connection - my app can't find them. Added my mobile phone to VPN director and totally lost connection via WiFi.
Re-enabled the remote server and got my phone connection back.
So it "appears" to be working fine with the same hardware.
Can someone direct me to the VPN client logfile so I can check and post relevant clips - if needed?
Ripshod
I've tested it to try and confirm your issue but it's working fine.
So it's likely there's a setting or plugin somewhere that's interfering.
When you flashed the 388.1 firmware you did do a factory reset after didn't you?
copydeskcat
When I flash any version, I do a full reboot/restart. Why would I need to do a factory reset - surely I’d lose all my settings etc if I did that?
Ripshod
Don't worry about that right now. Killswitch isn't working for me either.
Strange how it worked for my first test but now it isn't.
Any clues anyone?
Viktor Jaep
Any clues anyone?
From what I understand (buried in another thread), the Killswitch only functions if the VPN connection is severed externally, crashes, etc. If you shut your connection down manually or programmatically, Killswitch doesn't work, and reverts to your open WAN. I'm sure someone can correct me if I'm wrong and point to the source.
Ripshod
That's exactly what I did. I shut down the remote VPN server. Sudden disconnection. Devices were still showing connected to the internet and were still accessible via my android phone app but showed my public IP, with nothing in the logs.
I've set everything back up as it was and the killswitch in YazFi seems to work fine.
I did not kill the client - I killed the remote server.
Edited to add fuller information.
copydeskcat
That's exactly what I did. I shut down the remote VPN server. Sudden disconnection. Devices were still connected and accessible, and nothing in the logs.
I didn’t kill the VPN manually. It just stopped working (often, if the node reaches capacity, it kicks you off). The kill switch didn’t work in this circumstance.
Viktor Jaep
I'm not quite sure how to explain it. I'll see if I can dig up the documentation/methodology.
EDIT: here's an interesting discussion threat that might leave more questions than answers... ;)
And here's another with lots more info from RMerlin himself for your reading pleasure...
