The title pretty much says it all. I want to set up dual WAN where WAN 1 is available exclusively to one client, and all other clients use WAN 2. My router is the AX86U.
This can be done as described here: https://www.snbforums.com/threads/a...t-only-one-device-to-use-secondary-wan.68773/
However, what I also want is, if WAN 2 has an outage, then WAN 1 becomes available to all clients.
So it's like load balancing + failover. Is this possible in stock firmware without having to input code? Does it just happen by default or will the router leave clients who were not assigned to WAN 1 without connectivity if WAN 2 fails? (I can't test it yet).
Thanks!
Thanks!
