tonymet
I recently "upgraded" to Asus RT-AC5300 – a top-tier AP with tri-band, band steering and lots of resources.
Working well, but one setback: my pings have regressed: To
3.0ms AVG from 1.8ms AVG prior to the test
How I tested
What I've tried
* factory reset
* disable beamforming, airtime fairness, TX Burst
* reduce power on 3 bands to "balanced"
Results
Jan 5 is when the new Asus AC5300 was installed as AP
How I tested
- Router was the same in all tests ( UBNT Edge Router X)
- ping Results are from a Raspberry Pi 3 with smokeping . Ping is to the gateway (on the router). Pinging the AP directly has similar results.
- Multiple separate APs were tested prior (tp link archer C7, tp link AX3000, tp leak eap225 (enterprise) )
- what wifi settings should I test that affect latency?
- What are typical AP pings people are getting?
What I've tried
* factory reset
Results
