realslicedbread
I want to setup my new flat with two routers, connected via gigabit ethernet, to increase wifi coverage.
I'm currently undecided between two Asus AC68U's, or two Netgear R7000's.
I just have a few questions on how to wire the routers once I get them. My cable modem enters the flat in the living room and this is where I'll have my HTPC, consoles etc as well. So the cable modem will connect to the WAN port of the first router, and the consoles etc will connect to the LAN ports.
Obviously one LAN port will connect to my second router. The second router will be in bridge mode, and will be in my study. I'll have my computers/NAS/servers connected to this second router.
Does the ethernet from my first/main router plug into the WAN port or a LAN port of the second router?
Also is it possible to setup the routers to create a unified wifi network across the flat? I'm trying to get seamless wifi switching between the two routers as I walk across the flat, without having to use separate SSIDs.
Thanks.
Thanks.
