Solved AC68U antenna question
skeal
Part of the Furniture
My original antennas that came with my AC68U are in rough shape, I would like to change them out. Can I take the antennas off my deceased AC3100 and use them on the AC68U? What should I watch for?
GHog
They work perfect. I bought some antennas for the RT-AC88u, I believe the same router, and I actually got better radio range and performance with that upgrade. Nothing to watch out for from my end.
det721
Yes both routers and antennas are duel band i see no reason you would have any issues swapping them out.
