AiMesh node still connecting on wifi even when wired
fields987
My aimesh node is hardwired. The primary router shows it as connection priority ethernet and connection type wired. But in my system log/wireless log, i show an "unknown device" with the mac of of the wl0.1 interface on the aimesh node. Not sure if this a bug, misconfiguration, or expected behavior.
Also, do I need to use Roaming assistant in conjunction with AiMesh, or is roaming assistant only for APs outside of an AiMesh configuration?
Thanks for any help.
I think it is expected behavior. Using a wired backhaul doesn't disable the wireless backhaul... it remains available, if needed.
I think you use Roaming Assistant anytime you want to encourage roaming.
OE
Network Map/ AI Mesh Node/ click on node to check connection on/ more config/
You can then select the connection you want it to use wifi or cabled
OP noted this in his second sentence.
OE
