Asuswrt-Merlin 376.47 is out
RMerlin
Asuswrt-Merlin dev
Staff member
Howdy folks,
Asuswrt-Merlin 376.47 is now available for all supported models.
The highlights over 376.46:
  • Merge with Asus's 376_2678 GPL code, which brings various fixes and improvements to the RT-AC87U (DPI and wifi), more work surrounding USB 3G/4G modems, and some more fixes and tweaks.
  • SNMP support has been enabled on all models (except the RT-N16, since Asus's MIBs require OpenVPN to be compiled in). This is a feature that's still in development by Asus, so consider this as being experimental. You can enable and configure it under Administration -> SNMP.
  • FTP and Samba AiCloud syncing. Again, another feature that Asus is still working on, and should be considered as experimental.
  • SSH now supports SHA256 and SHA512 HMAC, in response to SHA-1 being gradually phased out on the rest of the Internet.
  • Numerous fixes to the VPN webui
Downloads are here.
Changelog is here.
MD5 checksums:
018da9bea81524ecdcd6167002ce7270  RT-AC56U_3.0.0.4_376.47_0.trx
0afc4edd8fbac44423aafe8286e1e98b  RT-AC66U_3.0.0.4_376.47_0.trx
0dbf20d532e0ee15bede5d2a9e69d0c3  RT-AC68U_3.0.0.4_376.47_0.trx
4aa22d77e6a430466acbc0be32c44cce  RT-AC87U_3.0.0.4_376.47_0.trx
344da8ba1048a9811670800e9d90c547  RT-N16_3.0.0.4_376.47_0.trx
b3d08882989460ea5ab944b51d3e433c  RT-N66U_3.0.0.4_376.47_0.trx
Thank you!
Updated smoothly on my 68U. Did a factory reset, first time since .39 upgrade. Running fine. Thank you for the hard work, RMerlin. Much appreciated.
Also updated with no issues. I must be feeling lucky, I am going to leave the router as-is as long as I have no issues with it. No factory reset, yet. :)
I predict another RMerlin classic from day one. ;)
376.47
Updated and using now.
Thanks for all the hard work RMerlin!
gotwillk, If you're just using basic LAN and WiFi, give it a shot without a reset.
If you're using any advanced options (USB disks, printers, VPN, etc.) then I would recommend to disconnect all USB devices, save any special settings you've created (for example, in the JFFS partition), reboot the router and after waiting a good 5 minutes or so, upgrade the firmware.
After it has upgraded, do a factory reset and after doing a preliminary setup, manually of course, I would power cycle the router (physically pull the power plug) instead of just rebooting it.
Now, you should be at a known and stable point to try any adjustments to the newly available settings.
decided to try this new version on my RT-AC68R, My hard drive finally mounts again!, I still get the following error though:
Fail to get log of fsck!
the usb 3.0 icon have a red circle around it but atleast it now mounts and I can use it. I tried a factory reset just in case but it still happens. The drive is a Samsung 4tb D3 Station. Also tried reducing the usb 3.0 interference but no change.
thank you! yes i am using only basic LAN and wifi. i'll just do a flash without factory reset and see how it turns out. if anything, i guess i'll just reconfigure the settings.
Does the USB 2.0 port do the same? What format does the drive have?
Just went from the beta to the release version. This time no issues with the apps that are on my usb drive starting via the mount script, both nginx and squid started just fine. So far looking good. Thanks Merlin.
yes same problem, formatted NTFS, here is a system log after the upgrade, maybe it will help find the problem
I also noticed that now there is a folder in my hard drive named ntfsck.00000000 with a couple files in it, is it possible the firmware is corrupting my files? files in the folder are file.00000000 and file.00000001
Sep 20 17:08:53 rc_service: ntp 887:notify_rc restart_upnp
Sep 20 17:08:53 miniupnpd[874]: shutting down MiniUPnPd
Sep 20 17:08:53 rc_service: ntp 887:notify_rc restart_diskmon
Sep 20 17:08:53 rc_service: waitting "restart_upnp" via ntp ...
Sep 20 17:08:53 miniupnpd[910]: HTTP listening on port 39794
Sep 20 17:08:53 miniupnpd[910]: Listening for NAT-PMP/PCP traffic on port 5351
Sep 20 17:08:54 dnsmasq-dhcp[790]: DHCPREQUEST(br0) 192.168.1.210 ac:22:0b:be:61:bd
Sep 20 17:08:54 dnsmasq-dhcp[790]: DHCPACK(br0) 192.168.1.210 ac:22:0b:be:61:bd Bedroom-PC
Sep 20 17:08:54 disk monitor: be idle
Sep 20 17:08:57 dnsmasq-dhcp[790]: DHCPDISCOVER(br0) 64:66:b3:d2:e3:b6
Sep 20 17:08:57 dnsmasq-dhcp[790]: DHCPOFFER(br0) 192.168.1.171 64:66:b3:d2:e3:b6
Sep 20 17:08:57 dnsmasq-dhcp[790]: DHCPREQUEST(br0) 192.168.1.171 64:66:b3:d2:e3:b6
Sep 20 17:08:57 dnsmasq-dhcp[790]: DHCPACK(br0) 192.168.1.171 64:66:b3:d2:e3:b6 TL-WR702N
Sep 20 17:09:01 hotplug[836]: USB /dev/sda1(ntfs) failed to mount at the first try!
Sep 20 17:09:01 kernel: tntfs: fail_safe is enabled
Sep 20 17:09:01 kernel: tntfs info: NTFS volume name 'SAMSUNG', version 3.1 (cluster_size 4096, PAGE_CACHE_SIZE 4096).
Sep 20 17:09:06 hotplug[836]: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/SAMSUNG
Sep 20 17:09:09 crond[592]: time disparity of 1956788 minutes detected
Sep 20 17:09:12 dnsmasq-dhcp[790]: DHCPREQUEST(br0) 192.168.1.104 00:1d:fe:db:7d:3d
Sep 20 17:09:12 dnsmasq-dhcp[790]: DHCPACK(br0) 192.168.1.104 00:1d:fe:db:7d:3d android-9e3169c6bb4b3e9c
Sep 20 17:09:12 admin:  sh /opt/S50asuslighttpd.1 start
Sep 20 17:09:14 dnsmasq-dhcp[790]: DHCPREQUEST(br0) 192.168.1.2 f8:f1:b6:30:4b:f7
Sep 20 17:09:14 dnsmasq-dhcp[790]: DHCPACK(br0) 192.168.1.2 f8:f1:b6:30:4b:f7 android-663248472dc0b46b
Sep 20 17:09:16 admin:  sh /opt/S50downloadmaster.1 start
Sep 20 17:09:22 transmission-daemon[2063]: Transmission 2.82 (14160) started (session.c:744)
Sep 20 17:09:22 transmission-daemon[2063]: RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:828)
Sep 20 17:09:22 transmission-daemon[2063]: RPC Server Adding address to whitelist: *.*.*.* (rpc-server.c:828)
Sep 20 17:09:22 transmission-daemon[2063]: RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:1035)
Sep 20 17:09:22 transmission-daemon[2063]: RPC Server Whitelist enabled (rpc-server.c:1039)
Sep 20 17:09:22 transmission-daemon[2063]: Couldn't bind port 51413 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:371)
Sep 20 17:09:22 transmission-daemon[2063]: UDP Failed to set receive buffer: requested 4194304, got 241664 (tr-udp.c:78)
Sep 20 17:09:22 transmission-daemon[2063]: UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:83)
Sep 20 17:09:22 transmission-daemon[2063]: UDP Failed to set send buffer: requested 1048576, got 241664 (tr-udp.c:89)
Sep 20 17:09:22 transmission-daemon[2063]: UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:94)
Sep 20 17:09:22 transmission-daemon[2063]: DHT Reusing old id (tr-dht.c:306)
Sep 20 17:09:22 transmission-daemon[2063]: DHT Bootstrapping from 63 IPv4 nodes (tr-dht.c:154)
Sep 20 17:09:22 transmission-daemon[2063]: Using settings from "/tmp/mnt/SAMSUNG/Download2/config" (daemon.c:697)
Sep 20 17:09:22 transmission-daemon[2063]: Saved "/tmp/mnt/SAMSUNG/Download2/config/settings.json" (variant.c:1217)
Sep 20 17:09:22 transmission-daemon[2063]: Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:73)
Sep 20 17:09:22 transmission-daemon[2063]: Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:73)
Sep 20 17:09:30 transmission-daemon[2063]: Port Forwarding State changed from "Not forwarded" to "Starting" (port-forwarding.c:95)
Sep 20 17:09:31 rc_service: hotplug 836:notify_rc restart_nasapps
Sep 20 17:09:31 iTunes: daemon is stopped
Sep 20 17:09:31 FTP Server: daemon is stopped
Sep 20 17:09:31 Samba Server: smb daemon is stopped
Sep 20 17:09:31 kernel: gro disabled
Sep 20 17:09:31 Timemachine: daemon is stopped
Sep 20 17:09:31 kernel: gro enabled with interval 2
Sep 20 17:09:33 transmission-daemon[2216]: Transmission 2.82 (14160) started (session.c:744)
Sep 20 17:09:33 transmission-daemon[2216]: RPC Server Adding address to whitelist: 127.0.0.1 (rpc-server.c:828)
Sep 20 17:09:33 transmission-daemon[2216]: RPC Server Adding address to whitelist: *.*.*.* (rpc-server.c:828)
Sep 20 17:09:33 transmission-daemon[2216]: RPC Server Serving RPC and Web requests on port 127.0.0.1:9091/transmission/ (rpc-server.c:1035)
Sep 20 17:09:33 transmission-daemon[2216]: RPC Server Whitelist enabled (rpc-server.c:1039)
Sep 20 17:09:33 transmission-daemon[2216]: Couldn't bind port 51413 on ::: Address already in use (Is another copy of Transmission already running?) (net.c:371)
Sep 20 17:09:33 transmission-daemon[2216]: UDP Failed to set receive buffer: requested 4194304, got 241664 (tr-udp.c:78)
Sep 20 17:09:33 transmission-daemon[2216]: UDP Please add the line "net.core.rmem_max = 4194304" to /etc/sysctl.conf (tr-udp.c:83)
Sep 20 17:09:33 transmission-daemon[2216]: UDP Failed to set send buffer: requested 1048576, got 241664 (tr-udp.c:89)
Sep 20 17:09:33 transmission-daemon[2216]: UDP Please add the line "net.core.wmem_max = 1048576" to /etc/sysctl.conf (tr-udp.c:94)
Sep 20 17:09:33 transmission-daemon[2216]: DHT Reusing old id (tr-dht.c:306)
Sep 20 17:09:33 transmission-daemon[2216]: DHT Bootstrapping from 63 IPv4 nodes (tr-dht.c:154)
Sep 20 17:09:33 transmission-daemon[2216]: Using settings from "/tmp/mnt/SAMSUNG/Download2/config" (daemon.c:697)
Sep 20 17:09:33 transmission-daemon[2216]: Saved "/tmp/mnt/SAMSUNG/Download2/config/settings.json" (variant.c:1217)
Sep 20 17:09:33 transmission-daemon[2216]: Port Forwarding (NAT-PMP) initnatpmp succeeded (0) (natpmp.c:73)
Sep 20 17:09:33 transmission-daemon[2216]: Port Forwarding (NAT-PMP) sendpublicaddressrequest succeeded (2) (natpmp.c:73)
Sep 20 17:09:33 Samba Server: daemon is started
Sep 20 17:09:33 miniupnpd[910]: HTTP Connection from 192.168.1.210 closed unexpectedly
Sep 20 17:09:41 transmission-daemon[2216]: Port Forwarding State changed from "Not forwarded" to "Starting" (port-forwarding.c:95)
Sep 20 17:11:11 dnsmasq-dhcp[790]: DHCPREQUEST(br0) 192.168.1.104 00:1d:fe:db:7d:3d
Sep 20 17:11:11 dnsmasq-dhcp[790]: DHCPACK(br0) 192.168.1.104 00:1d:fe:db:7d:3d android-9e3169c6bb4b3e9c
Sep 20 17:11:41 transmission-daemon[2216]: Port Forwarding State changed from "Starting" to "???" (port-forwarding.c:95)
so far so good
installed form the Beta... have not done a factory reset after the install...everything is working fine.
Hi Merlin, still issues with the VPN GUI. With no VPN servers running I still get "OpenVPN Server 1 - Running"
Make sure you select the OpenVPN instance when checking its state. If the status page shows it as running, then there must be a process running on the router for that specific instance.
sqlite version not matching with mindlna
AC66U
hi, thx for your great job !
i updated from the version 45 without a factory reset with no main problems ( i just use samba, dhcp filter and dnla sever) but
when i tried to use the dlna server with a fresh database i got the message : SQLite library is not threadsafe! Inotify will be disabled.
so i checked the src and :
in minidlna.c :
1171 if (!sqlite3_threadsafe() || sqlite3_libversion_number() < 3005001)
1172 DPRINTF(E_ERROR, L_GENERAL, "SQLite library is not threadsafe! "
1173 "Inotify will be disabled.\n");
as i am a noob linux, should u tell me what is the cmd in order to check my sql version?
so the dlna server is completly useless because the database wont update with change's files.
may i have to push a factory reset in order to solve this or it's an issue from the code?
I also noticed in the .45 the the wifi power slider seems to not working (1 % or 100% gives me full power), in the .47 i get the same issue.
best regards,
Edit: i tried a factory reset: the sql issue was still here, then i gone back to .45 (no sql issue) because i need the dlna server.
Updated today and so far everything is working great. I amusing Entware with Tranmission on a USB drive and so far it's all working great as well.
Fixed it, under VPN Details, which I had set for PPTP as I don't use OpenVPN, I cycled it through PPTP/OpenVPN and the OpenVPN running status cleared.
Hi Merlin, it seems it was fixed a very old bug with the NFS service start: now it works without any intervention!
Many thanks man! :D
I'm on 376.45 which is running fine so far, so is this release recommended over 376.45? E.g. more secure or stable?
