Asuswrt Merlin, resolve client lan names on server-side?
nadieaqui
Asuswrt Merlin:
I have a bidirectional OpenVPN connection running on 2 Asuswrt Merlin routers (firmware is current).
But, I cannot perform a "nslookup pc.client.lan" on the OpenVPN Server?
What I would like to do is resolve client lan names on the server.
Does anyone know of a solution?
[I spent several days searching and trying but could not find a solution]
server lan: 192.168.0.x
client lan: 192.168.1.x
Here is what I can do:
client> nslookup pc.server.lan
client> ping pc.server.lan
server> ping ip-client-lan (e.g. 192.168.1.25)
Here is what I *cannot* do:
server> nslookup pc.client.lan
server> ping pc.client.lan
eibgrad
Make sure DNSMasq is configured on both sides w/ the following directive.
interface=tun*
This tells the DNS servers to listen for queries from the OpenVPN tunnel's network interface. By default, they will only listen to the default network interface (br0).
nadieaqui
interface=tun*
That was the solution. Thank You!
nadieaqui
interface=tun*
I upgraded the Client to Merlin 384.16.
And,
1) I have "interface=tun*" in DNSMasq on both server and client.
2) Client has "Inbound Firewall" = Allow
However, the OpenVPN server cannot resolve client lan names.
[FYI: before posting, I tried searching but could not find a solution]
nadieaqui
And,
Solved. Add client domain name (client.lan) and its DNS server (192.168.1.1) to Server DNSMasq; Client has "Inbound Firewall" = Allow; and reboot server.
For example, in dnsmasq.conf.add on OpenVPN Server -- I have the following lines
interface=tun*
server=/client.lan/192.168.1.1
now, this works.
