I have an AiMesh network set up with an RT-AC86U as the parent node and an RT-AX56U as a satellite node
This has been setup for over a year without issues. However recently I updated the firmware for the both the routers and first of all found my RT-AX56U now indicates via a red LED that it has no uplink connection, which is false as everything connected to it has a perfect connection and the admin software also shows a connection (wired 1Gbps). I'm guessing this is a bug and can live with it.
However more annoying is that I think since the firmware update connection to the AX56U via 2.5Ghz WIFI is unreliable with several devices reporting that they couldn't get an ip address or something similar. If I reboot the router I can connect no issues the first time but if disconnect and reconnect the issue returns. I can't say for sure if this started happening after the firmware update as I tend to use 5Ghz for most devices, I only noticed when out in the garden and I was trying to connect to the stronger 2.4Ghz on my phone (Galaxy S20) to test coverage. I have no issues when connecting to the RT-AC86U on 2.4GHZ
It's not the biggest issue as most of my devices are either wired or using 5Ghz but I'm just slightly frustrated that if I wanted to use a stronger signal at the bottom of the garden I now can't reliably, niche issue I know but on the one day in Scotland that I get sunshine in summer I'd like to have the option of full connectivity.
Before I go through the time consuming business of a factory reset I was just wondering if anyone else had experienced this...is there now an issue running a WiFi 6 satellite node with a WiFi 5 parent node, should I be looking to upgrade my trusty RT-AC86U? Can't see how this would impact the DHCP but you never know.
Current firmware detail below:
RT-AC86U - 3.0.0.4.386_45956
RT-AX56U - 3.0.0.4.386_45934
