GT-AX11000 VPN Director not working for me
jbilodea
Maybe something I don't understand.
I use VPN director but when I put a rule for my PC (192.168.1.145) it works, the VPN is active for that PC. I added 192.168.1.0/24 for WAN and all wireless do not have access to the internet. Any idea what I did wrong ? I know in my picture the VPN is disabled.
octopus
Part of the Furniture
Do you use GW1 on 2,4Ghz and GW1 on 5.0Ghz, they are on different net. 192.168.101.0 192.168.102.0
octopus
Sorry I don't know what GW1 is. I even selected my cell phone IP in the rule for WAN and it does not work either.
Sorry, Guest network 1
RMerlin
Asuswrt-Merlin dev
Your very first rule says to redirect all traffic through the WAN, so no traffic will ever reach the OVPN rules.
octopus
This router is new with Asuswrt-Merlin, is it possible it is a bug ?
That's is not a bug, to many people have it working including mine.
You are sure client is running? Can't se you icon is green.
2-Screenshot 2023-03-10 at 19-15-11 ASUS Wireless Router RT-AX86U Pro - VPN Director.png
jbilodea
For sure ! After enabling it, I then tested the speed on my PC and it is 4X slower (which is normal due to VPN) so my PC is using the VPN. But all other devices (they are wifi) are unable to connect to the internet
octopus
Then i really don't know why!
octopus
octopus
Same as me then.
My rules are as this:
192.168.50.0/24 WAN
192.168.50.150 OVPN1
192.168.50.239 OVPN1
VPN Director (policy rules)
octopus
YOU ARE THE WINNER !!!! It works now ! Before I entered 192.168.1.0/24, after looking at YOUR rules I entered 192.168.1.1/24 and BANG! it works. So never use 0 I guess.
Ok nice you get it working. I'm using 192.168.50.0/24 rule strange
