Qos setting question
ac66ub1
I want to surf internet and bittorent download at same time,internet surf use bandwidth as more as need, force bittorent can only use rest bandwidth.
It's hard to find the setting example or tutorial,I don't understand why.
I set Adaptive QoS as below:
But it seemed not ok, lots of error in my log as below:
May 27 9:21:23 kernel: htb: htb qdisc 12: is non-work-conserving?
May 27 9:25:05 kernel: htb: htb qdisc 12: is non-work-conserving?
May 27 9:53:22 rc_service: httpd 291:notify_rc restart_qos;restart_firewall
May 27 9:53:29 kernel: ERR[parse_qos_conf:932] Can't set new QoS conf while QoS is started!
May 27 9:53:29 kernel: ERR[ioctl_iqos_op_config:3592] parse qos_conf error!!
May 27 9:53:29 kernel: ioctl_iqos_op_config() fail!
May 27 9:53:29 kernel: ERR[qos_start:3344] QoS is already started!
May 27 9:53:29 kernel: ioctl_iqos_op_switch(1) fail!
May 27 9:53:32 kernel: ERR[parse_qos_conf:932] Can't set new QoS conf while QoS is started!
May 27 9:53:32 kernel: ERR[ioctl_iqos_op_config:3592] parse qos_conf error!!
May 27 9:53:32 kernel: ioctl_iqos_op_config() fail!
May 27 9:53:32 kernel: ERR[qos_start:3344] QoS is already started!
May 27 9:53:32 kernel: ioctl_iqos_op_switch(1) fail!
May 27 9:53:38 nat: apply nat rules (/tmp/nat_rules_eth0_eth0)
May 27 9:54:01 kernel: htb: htb qdisc 12: is non-work-conserving?
This question is not related to official firmware,that answer is not helpful.
The answer is correct and appropriate , however the ignorance and rudeness you have shown in many posts since you started spamming this forum are becoming very tiresome.
There is a SEARCH facility , you should use it , your questions have mostly been asked and answers many times before.
All ASUS routers are supplied with a User Manual and the GUI has help information on most pages , there are also direct links to the User Manual/FAQ's on almost every page of the GUI.
You have criticized ASUS, complained that Merlin is not good enough and insult those that answer your endless queries .......
You'll very soon find yourself in a quiet , lonely corner.
enjoy her lovely avatar and forgive.
Not all are used to facebook & co where you only allowed to like and no dislike exists.
Others just write what they think like man did in the past - just the truth, without flowers and hearts ...
And yes, there are a lot of troubles since 382, it should be allowed in a (self-designated) open forum to say this or ask for improvements.
There is no other known place asus is reading ...
