1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Dismiss Notice
Welcome To SNBForums
R7800 Error: No space left on device - Trying to install Entware
Discussion in 'NETGEAR AC Wireless' started by Giaki, Mar 29, 2020.
Tags:
  1. Giaki
    Giaki New Around Here
    Mar 13, 2020
    6
    I flashed the latest Voxel firmware on a R7800 (75.2) and I decided to try to install Entware.
    I went through the readme but when I arrived at creating the swap file I got an error that said I hadn't enough space on my usb flash. I read that that was an optional step so i skipped this but maybe this is the cause of the problem I econtered later, "Error: No space left on device".
    So I couldn't finish this step:
    "Reboot router again. After this use “/opt/bin/opkg update” and “/opt/bin/opkg upgrade” Entware repository. Install and use necessary for you packages."
    Was an usb flash drive supposed to be left connected to the router to use Entware?
    Should I make a swap file before on the flash drive using gparted?
    Thank you
  2. L&LD
    L&LD Part of the Furniture
    Dec 9, 2013
    12,614
    How big is your USB drive? How is it formatted? How much free space does it actually have (on a PC, for example)?
    Voxel likes this.
  3. Voxel
    Voxel Very Senior Member
    Dec 9, 2014
    1,644
    As far as I understand you try to install Entware into internal flash of your router. Check my README and clear your /opt directory from Entware/swap. "/opt" by default is internal memory flash. "bin", "etc", "home" etc should be symlinks in /opt. But not ordinary directories. You have to install initial Entware from my tarball. Reboot router. etc. README.
    Voxel.
    L&LD likes this.
  4. Giaki
    Mar 13, 2020
    6
    The pendrive is 16gb, ext2, almost empty, only entware tar inside.
    Maybe the problem was that I removed the pendrive after I install the initial Entware, I didn't know that only 32mb of flash memory is actually available on the router and that I was supposed to leave a pendrive mounted in to extended the router's memory via symlinks.
    To clear out /opt and /swap I can simply delete all files inside those foldcrs?
    And to make the swap file, should I create it earlier with gparted?
    Thank you again
    edit.
    I did it from scratch, same problems. :(
    This time I left the usb drive connected to the router, created the swap file, copy paste these commands:
    mkswap swap
    chmod 0600 swap
    swapon swap
    After reboot (copy-paste from console):
    [email protected]:~$ /opt/bin/opkg update
    Downloading http://www.voxel-firmware.com/Downloads/Voxel/Entware/Entware-3x-Voxel/Packages.gz
    Updated list of available packages in /opt/var/opkg-lists/entware
    [email protected]:~$ /opt/bin/opkg upgrade
    Upgrading terminfo on root from 6.1-4 to 6.2-1...
    Upgrading libc on root from 2.26-8 to 2.26-9...
    Upgrading opkg on root from 2019-01-31-d4ba162b-1 to 2019-06-14-dcbc142e-2...
    Upgrading wget on root from 1.20.3-1 to 1.20.3-3...
    Upgrading libpthread on root from 2.26-8 to 2.26-9...
    Upgrading zoneinfo-europe on root from 2019a-1 to 2019c-1...
    Upgrading libpcre on root from 8.43-1 to 8.43-2...
    Upgrading zoneinfo-asia on root from 2019a-1 to 2019c-1...
    Upgrading libstdcpp on root from 7.4.0-8 to 8.4.0-9...
    Upgrading libgcc on root from 7.4.0-8 to 8.4.0-9...
    Upgrading librt on root from 2.26-8 to 2.26-9...
    Upgrading findutils on root from 4.6.0-3 to 4.7.0-1...
    Upgrading libssp on root from 7.4.0-8 to 8.4.0-9...
    Upgrading libopenssl on root from 1.1.1c-5 to 1.1.1e-1...
    Collected errors:
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg terminfo needs 7
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libc needs 1217
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg opkg needs 68
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg wget needs 239
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libpthread needs 42
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg zoneinfo-europe needs 21
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libpcre needs 174
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg zoneinfo-asia needs 31
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libstdcpp needs 454
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libgcc needs 24
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg librt needs 12
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg findutils needs 184
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libssp needs 4
    * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libopenssl needs 1246
    I think it's trying to install packages on the internal memory, what I'm missing?
    Thank you
  5. Voxel
    Dec 9, 2014
    1,644
    (1) /opt
    Yes, just remove everything from /opt. I.e. run the commands:
    rm -rf /opt
    reboot
    (2) /swap
    Swap should NOT be created at the root location of your router! Again: please check README. It should be on your USB drive i.e. /mnt/sda1/swap. I.e. to fix it:
    rm -f /swap
    reboot
    (3) Use ext4 instead of ext2: it is more advanced and more safe for your data. How: see (4) below.
    (4) Run the steps (1) and (2) from the post:
    https://www.snbforums.com/threads/c...4-2sf-v-1-0-2-74-3sf.61962/page-3#post-557147
    after that:
    cd /mnt/sda1
    wget https://voxel-firmware.com/Downloads/Voxel/Entware/entware-cortex-a15-3x-initial-generic.tar.gz
    tar xf entware-cortex-a15-3x-initial-generic.tar.gz
    dd if=/dev/zero of=swap bs=1024 count=1048576
    mkswap swap
    chmod 0600 swap
    reboot
    (5)
    And only after that
    Voxel
    spocko, kamoj and pege63 like this.
  6. Giaki
    Mar 13, 2020
    6
    I followed all you instructions but same error.
    Can't understand what's wrong.
    I take out the pendrive, turned off the router, format the pendrive to ext4 with my linux NB, plugged pendrive to the router and then did these commands:
    mkfs.ext4 -L optware -O ^64bit /dev/sda1
    tune2fs -O ^metadata_csum /dev/sda1
    cd /mnt/sda1
    wget https://www.voxel-firmware.com/Downloads/Voxel/Entware/entware-cortex-a15-3x-initial-generic.tar.gz
    sync
    reboot
    cd /mnt/sda1
    mkswap swap
    chmod 0600 swap
    swapon swap
    reboot
    no errors.
    The last two instructions (update and upgrade) are writing on the internal memory, I suppose.
    Downloading http://www.voxel-firmware.com/Downloads/Voxel/Entware/Entware-3x-Vox                      el/Packages.gz
    Collected errors:
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg termi                      nfo needs 7
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libpt                      hread needs 42
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg zonei                      nfo-europe needs 21
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libpc                      re needs 174
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg zonei                      nfo-asia needs 31
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libst                      dcpp needs 454
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libgc                      c needs 24
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg findu                      tils needs 184
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libss                      p needs 4
     * verify_pkg_installable: Only have 0kb available on filesystem /opt, pkg libop                      enssl needs 1246
    [email protected]:~$ ls -al /mnt/sda1
    drwxr-xr-x    6 root     root         4096 Mar 30 18:14 .
    drwxr-xr-x    3 root     root           80 Jan  1  1970 ..
    drwxr-xr-t    2 root     root         4096 Mar 30 18:14 .ReadyDLNA
    drwxr-xr-x    3 root     root         4096 Jan 16  2019 autorun
    drwxr-xr-x   12 root     root         4096 May 25  2019 entware
    -rw-r--r--    1 root     root      5536132 Jun  7  2019 entware-cortex-a15-3x-in                      itial-generic.tar.gz
    drwx------    2 root     root        16384 Mar 30 18:03 lost+found
    -rw-------    1 root     root    1073741824 Mar 30 18:12 swap
    [email protected]:~$ ls -al /mnt/sda1/autorun
    drwxr-xr-x    3 root     root         4096 Jan 16  2019 .
    drwxr-xr-x    6 root     root         4096 Mar 30 18:14 ..
    drwxr-xr-x    2 root     root         4096 Jan 16  2019 scripts
    [email protected]:~$ ls -al /mnt/sda1/autorun/scripts
    drwxr-xr-x    2 root     root         4096 Jan 16  2019 .
    drwxr-xr-x    3 root     root         4096 Jan 16  2019 ..
    -rwxr-xr-x    1 root     root         2048 Jan 16  2019 post-mount.sh
  7. Voxel
    Dec 9, 2014
    1,644
    Please run
    ls -al /opt
    df -h
    what it displays.
    Voxel.
  8. Giaki
    Mar 13, 2020
    6
    [email protected]:~$ ls -al /opt
    drwxr-xr-x    6 root     root         1256 Mar 30 18:09 .
    drwxr-xr-x    1 root     root          776 Mar 30 18:02 ..
    lrwxrwxrwx    1 root     root           25 Mar 30 18:09 bin -> /tmp/mnt/sda1/ent        ware/bin
    -rw-r--r--    1 root     root          175 Mar 30 18:02 dirlist
    lrwxrwxrwx    1 root     root           25 Mar 30 18:09 etc -> /tmp/mnt/sda1/ent        ware/etc
    -rw-r--r--    1 root     root          855 Mar 30 18:02 filelist
    lrwxrwxrwx    1 root     root           26 Mar 30 18:09 home -> /tmp/mnt/sda1/en        tware/home
    drwxr-xr-x    2 root     root          224 Oct 14 16:36 leafp2p
    lrwxrwxrwx    1 root     root           25 Mar 30 18:09 lib -> /tmp/mnt/sda1/ent        ware/lib
    drwxr-xr-x    4 root     root          648 Oct 14 16:39 rcagent
    drwxr-xr-x    2 root     root          296 Oct 14 16:39 remote
    lrwxrwxrwx    1 root     root           26 Mar 30 18:09 root -> /tmp/mnt/sda1/en        tware/root
    lrwxrwxrwx    1 root     root           26 Mar 30 18:09 sbin -> /tmp/mnt/sda1/en        tware/sbin
    lrwxrwxrwx    1 root     root           27 Mar 30 18:09 share -> /tmp/mnt/sda1/e        ntware/share
    lrwxrwxrwx    1 root     root           25 Mar 30 18:09 tmp -> /tmp/mnt/sda1/ent        ware/tmp
    lrwxrwxrwx    1 root     root           25 Mar 30 18:09 usr -> /tmp/mnt/sda1/ent        ware/usr
    lrwxrwxrwx    1 root     root           25 Mar 30 18:09 var -> /tmp/mnt/sda1/ent        ware/var
    -rw-r--r--    1 root     root            9 Mar 30 18:02 version
    drwxr-xr-x    3 root     root          504 Oct 14 16:35 xagent
    [email protected]:~$ df -h
    Filesystem                Size      Used Available Use% Mounted on
    tmpfs                   512.0k         0    512.0k   0% /dev
    ubi0:overlay_volume      49.8M     49.8M         0 100% /overlay
    overlayfs:/overlay       49.8M     49.8M         0 100% /
    /dev/sda1                 7.4G      1.1G      5.9G  16% /tmp/mnt/sda1
    tmpfs                   512.0k         0    512.0k   0% /hipplay/dev
    /dev/sda1                 7.4G      1.1G      5.9G  16% /hipplay/home/0external/        dc8fdc8e-e2f8-4f79-b27c-54032fc00a7b
    tmpfs                   236.1M         0    236.1M   0% /hipplay/dev/shm
  9. Voxel
    Dec 9, 2014
    1,644
    At least one serious problem. After your experiments. Your internal flash is over.
    No space left. Well. Your USB seems OK. But internal flash... Is not a secret why do you want to use Entware? Seems you are not so experienced in Linux administration, sorry...
    Simplest way for you is to reset to factory settings. And to install your configuration manually. To free your internal flash.
    Or if you think that you can do: all your changes are visible in /overlay. It is necessary to clear your wrong steps e.g. swap file or whatever else. I do not know what else there. Maybe entware. If you think that you can do it. Rest (already prepared Entware) is already OK: on your USB. Please do all this with no USB attached.
    Voxel.
    kamoj likes this.
  10. Giaki
    Mar 13, 2020
    6
    Thnk you for all your support, yes, I just starded learning Linux stuff, I'm sorry if I'm doing silly mistakes or asking obvious things.
    I'd like to use Entware to try adguard and wireguard (next thing to learn).
    I unplugged the usb drive, did a reset via the hole behind the router. ssh key is still there so I can connect either telnet and ssh.
    But overlay_volume is still full, I tried to delete /opt from inside ovelay folder but overlay is still full (strange).
    Tried mnt erase volume_overlay but I got an error, either from ssh and telnet:
    Could not open mtd device: overlay_volume
    Any suggestion how can I format overlay?
    Thank you
  11. Voxel
    Dec 9, 2014
    1,644
    Do not worry. No problems with this.
    Well. Adguard? No such package in Entware as far as I know. There is kamoj add-on allowing to block ads. Wireguard. First, you are using R7800 and it could support only wireguard-go. Second: will be not so fast vs e.g. OpenVPN client. Plus wireguard-go additional package (+wireguard-tools) does not require installation of Entware.
    Better do not try to do that. You could brick your router.
    Try to flash, say, any stock firmware. Reset to factory settings. And after that back to 75.2SF.
    P.S.
    Before doing this please publish here the output of
    ls -al /overlay
    ls -al /
    Voxel.
    Sizzlechest and kamoj like this.
  12. Giaki
    Mar 13, 2020
    6
    Well... I meant ad-block of course :D
    Still experimenting about adblocking, don't know if it's better doing this with a raspberry pi 4 (I tried adguard and pihole) or doing directly with the router.
    Good to know Wireguard-go vs OpenVPN, I thought that Wireguard was way better than OpenVPN. I could give a try to OpenVPN thus (150-30 FTTC).
    I wanted to try also kamoj add-on but I messed up the overlay so can't do any tinkering at the moment.
    Here is the output:
    [email protected]:~$ ls -al /overlay
    drwxr-xr-x    8 root     root          616 Mar 31 17:42 .
    drwxr-xr-x    1 root     root          616 Mar 31 17:42 ..
    -rw-r--r--    1 root     root           29 Jan  1  1970 .firmware_time
    drwxr-xr-x    6 root     root          584 Mar 30 16:03 etc
    drwxr-xr-x   16 root     root         1376 Mar 28 16:17 hipplay
    drwxr-xr-x    3 root     root          232 Mar 26 18:30 lib
    drwxr-xr-x    3 root     root          288 Mar 29 00:05 root
    drwxr-xr-x    3 root     root          224 Oct 14 14:39 usr
    drwxr-xr-x    3 root     root          224 Oct 14 14:35 www
    drwxr-xr-x    2 root     root          916 Mar 26 18:30 bin
    -rw-r--r--    1 root     root            9 Mar 26 18:33 cloud_version
    -rw-r--r--    1 root     root           11 Mar 26 18:33 default_language_version
    drwxr-xr-x    8 root     root         4620 Mar 26 18:44 dev
    drwxr-xr-x    1 root     root          584 Mar 30 16:03 etc
    -rw-r--r--    1 root     root            1 Mar 26 18:33 firmware_region
    -rw-r--r--    1 root     root           29 Mar 26 18:33 firmware_time
    -rw-r--r--    1 root     root           14 Mar 26 18:33 firmware_version
    -rw-r--r--    1 root     root            6 Mar 26 18:33 hardware_version
    lrwxrwxrwx    1 root     root            4 Mar 26 18:30 home -> /tmp
    -rw-r--r--    1 root     root           35 Mar 26 18:33 hw_id
    drwxr-xr-x    1 root     root          232 Mar 26 18:30 lib
    lrwxrwxrwx    1 root     root            8 Mar 26 18:30 mnt -> /tmp/mnt
    -rw-r--r--    1 root     root            6 Mar 26 18:33 module_name
    drwxr-xr-x    8 root     root          616 Mar 31 17:42 overlay
    dr-xr-xr-x  146 root     root            0 Jan  1  1970 proc
    drwxr-xr-x   15 root     root          436 Mar 26 18:33 rom
    drwxr-xr-x    1 root     root          288 Mar 29 00:05 root
    drwxr-xr-x    3 root     root         2374 Mar 26 18:30 sbin
    dr-xr-xr-x   15 root     root            0 Jan  1  1970 sys
    drwxrwxrwt   25 root     root         2360 Mar 31 23:11 tmp
    drwxr-xr-x    1 root     root          224 Oct 14 14:39 usr
    lrwxrwxrwx    1 root     root            4 Mar 26 18:30 var -> /tmp
    drwxr-xr-x    1 root     root          224 Oct 14 14:35 www
  13. e38BimmerFN
    e38BimmerFN Very Senior Member
    May 25, 2012
    1,072
    USA
    Voxel, is Entware supported on Orbi? I see that DNSCrypt and a couple of other items are in your release notes. I didn't see Entware listed...
  14. Voxel
    Dec 9, 2014
    1,644
    You probably missed this info. Check my QuickStart.txt in ZIP with Orbi firmware:
    4. Entware.
    You can use Entware prepared by me for R7500/R7800/R9000. It works fine with Orbi.
    (1) Prepare new USB stick or disk with ext2 or ext3 or ext4 filesystem from telnet/ssh
    Voxel.
  15. Voxel
    Dec 9, 2014
    1,644
    And BTW Entware is updated a bit. Including netdata.
    and do not download the package for its installation. Just:
    /opt/bin/opkg install <package_name>
    it is normal way to install the package. Downloading and installation manually from *.ipk for Entware is not needed as a rule.
    Voxel.
  16. e38BimmerFN
    May 25, 2012
    1,072
    USA
    Ok I wanted to confirm.
    I had started the installation. Using a HDD USB drive connected to the back of the RBR. Same kind of drive I used yesterday on my R7800 which I got working well with Netdata.
    I'm getting to this area during the setup:
    mkswap swap< Not working on Orbi
    I get a not found message: mkswap
    I used the:
    dd if=/dev/zero of=swap bs=1024 count=1048576 that proceeded the mkswap command.
    Did I miss something? All was good up to the mkswap command.
  17. Voxel
    Dec 9, 2014
    1,644
    Yes, you are right. I did not enable it for Orbi firmware. "I'll do in the next release. Use of swap is optional...
    Meanwhile there is a workaround:
    (1) Install swap-utils from Entware:
    /opt/bin/opkg install swap-utils
    mkswap swap
    (2) Change a bit /mnt/sda1/autorun/scripts/post-mount.sh by e.g. nano editor:
    nano /mnt/sda1/autorun/scripts/post-mount.sh
    Change
    /sbin/swapon $SWAP
    to
    /opt/sbin/swapon $SWAP
    Save file, exit nano, reboot.
    Voxel.
    anhrzg and kamoj like this.
  18. e38BimmerFN
    May 25, 2012
    1,072
    USA
    Ok will give this a try...
  19. e38BimmerFN
    May 25, 2012
    1,072
    USA
    Voxel, I'm try to do this again. I think that the tar file isn't being unpacked after it's downloaded:
    cd /mnt/sda1
    Reboot RBR
    [email protected]:/# ls -l /opt/*
    lrwxrwxrwx 1 root root 16 Apr 4 16:56 /opt/bitdefender -> /mnt/bitdefender
    [email protected]:/tmp/mnt/sda1# ls -l /opt/*
    lrwxrwxrwx 1 root root 16 Apr 4 16:46 /opt/bitdefender -> /mnt/bitdefender
    Is all I see...
    I can't do
    /opt/bin/opkg upgrade as this causes the following message: /opt/bin/opkg: not found
    Let me know what I'm missing...
  20. R. Gerrits
    R. Gerrits Regular Contributor
    Nov 12, 2019
    103
    shouldn't that be "tar xzf entware-cortex-a15-3x-initial-generic.tar.gz" ???
    Because it is a .tar.gz?
    otherwise, check if /mnt/sda1/autorun/scripts/post-mount.sh exists an can be executed. That script is responsible for enabling entware after reboot.
    anhrzg likes this.
