I had an "opps" moment due to tiredness in which I set the Asus WebUI HTTPS port to 8443 and the SSH Service port to 8443 as well. In the process of doing so I retained SSH access via Putty, but lost the ability to login via the WebUI. I was wondering how I can change those ports from SSH to retain access to the WebUI. I seem to be stuck on where the specific configuration files for those services are located. Likewise if I could just change the WebUI back to HTTP I could probably access it long enough to make the changes I need, although I haven't a clue as to where to start. Thanks.
