RT-AC68U with Asus PCE-AC68 adapter WIFI(5G) issue (solved)
Hello,
I had for a year a RT-AC66U router using always Merlin firmware without any issue and I'm very happy with it.
Today I upgraded my router with RT-AC68U model, I installed the latest Merlin firmware version (build 376.47), all seemed work fine, I can connect with WIFI(both 2.4G/5G) from my MacBook Air, iPad, and Windows Phone devices, but when I started my PC with Windows 8.1 which has a Asus PCE-AC68 WIFI adapter i'm only able to use WIFI on 2.4G network, the adapter don't even see the 5G signal anymore which I was used to connect. I try reset all with factory-default setting and the 5G signal reappears but after I end the initial setup, changing the default password of the router and changing the WIFI name and settings with password protection the 5G signal will disappear soon after, so I can only use 2.4G network. I decided to revert the firmware with the latest original from Asus (version 3.0.0.4.376.1663) and the issue disappears, I can connect both 2.4G or 5G WIFI network from my PC. I guess there is a compatibility issue with the Asus PCE-AC68 network adapter and the RT-AC68U router with Merlin firmware, the problem does not occur with the RT-AC66U router. It's really a pity, I was so happy with Merlin firmware but now i'm forced to use the original, anybody around as a PC with Windows 8.1 and this network adapter having the same issue using Merlin firmware? How to fix it?
Hello,
