Running Asuswrt-Merlin firmware in a VM, Docker, Virtualisation
gspannu
Is it possible to run Asuswrt-Merlin firmware (for AX88u) in a Virtual Machine on a Mac/PC? Say using VMWare or Parallels on a Mac? Or maybe as a Docker image?
I am trying to test various scripts in /jffs and it is quite cumbersome having to factory reset the router (whenever I break something in my code and render the router inaccessible)
I am assuming that the firmware is some sort of a Linux derivative, so running it in a VM environment should be theoretically possible. Anyone know of ways to do this?
No. This question has been asked before.
Thanks for the quick answer.
Openwrt can be run as a docker image or in Virtual Box - any specific (technical) reasons as to why Asuswrt-Merlin firmware cannot be run.
Most likely because it supports the x86 platform, but Merlin is either MIPS or ARM. That's why you can virtualize DD-WRT too; it also runs on the x86 platform. FT (FreshTomato) is also MIPS/ARM, so it can't be virtualized either.
I have not vetted this site, so please use due diligence. As the old general contractor I worked with to pre-install network wiring into a new building said, "you rarely get what you expect, but you always get what you inspect"!
Azeria Labs - Emulating ARM Router Firmware. This uses QEMU on Linux which does the ARM emulation. Also, Windows 11 now has an Android subsystem that runs ARM apps, but I envision loads of wood chips trying to use that (i.e. hack, hack, hack ...). Also on a new ARM-based M1 Mac, you might also be able to use QEMU or maybe Virtualbox without emulation.
@gspannu did you ever get this working? Did you try the Azeria Labs emulation @gerardr suggested? I was looking for a way to do this too.
