The number of APs around me here in my congested NYC home went from 12 to about 37 overnight (damn you Claus!!! ), and only God knows how many more baby monitors, cell phones, microwaves and all other sorts of 2.4GHz crud hit the airwaves over that time. As a result, my 2 story home that used to be very well covered by a single Asus RT-N16 running Tomato is now overmatched the point where I can't move more than 15 feet away from it without losing signal (and I won't depress you with talk of throughput, it's pathetic).
I've been toying with a number of different N routers to see if I could get my RSSI to improve watching inSSIDer, but it looks like the best I can do even sitting 5 feet from the router is about -25dbm.
I'm wondering what my options are here. I do have an army of Tomato-capable routers (an Asus RT-N16, an Asus RT-N12, and a TP-Link TL-WR841ND), and I've got wired ethernet in different spots in the house to accommodate them.
I've been contemplating a few possibilities:
- Set up the routers in a WDS configuration - I think that would improve coverage, but from what I understand, each hop down the line the throughput would be halved, and it seems to be wasteful since I'm wired in other locations.
- Set up the routers for meshed bridging with each AP connected via ethernet
- Pick up a dual-band router that supports 5GHz.
I've already done the obvious - varying channels (to no avail, if you see the graph it's like radiation central in here), moving around antenna orientation, moving the AP. The one other thing I think would obviously help would be dual band, but I'm guessing signal attenuation from 5GHz combined with my old NYC home isn't going to be very impressive, not to mention I have no dual band equipment at the present (and that's 3 USB adapters I'd have to buy for the laptops, put aside the new router I'd need).
Would bridging the wireless network through an ethernet backend help at all?
Open to other ideas, if you've got one, please let me know!
Thanks,
-John
Thanks,
-John
