cengoe
Hello,
I would like to build a mesh system, and looking at asus aimesh.
I looked at different routers but not sure where to start for a main router.
I plan to use one high quality main router and a lower one in mesh, connected through ethernet cable, and my rt-n18u attached as a different ap (no mesh), connected to the router in the basement, later another mesh node replacing it.
I plan to buy something from AX line in the mesh, although nothing at home can currently use it.
We do not use wifi heavily, my pc and work notebook would be on ethernet, so I do not really care about mimo or mu-mimo, for now. I feel im ok with a 2x2.
I do have some shelly relays on wifi though that need to be reliable, even my heating would use it. Any feature that helps my smart devices is a plus, like automatic static ip-s for relays or something.
I would like to use an external drive on usb and printer, so 2 usb-s would be nice.
I never used merlin, im not a customizing type of guy, but if i get something for these, id use it happily.
I looked at different tech specifications, like a86u but im not sure if Id use 1gb ram or a higher frequency soc. Im probably not a power user, so a weaker would suffice.
Any suggestions?
Thank you!
Any suggestions?
Thank you!
