News [ 386.3_Alpha Build(s) ] Testing available build(s)
octopus
https://onedrive.live.com/?authkey=!AGY2taGX02nVmWA&id=CCE5625ED3599CE0!1427&cid=CCE5625ED3599CE0
New builds available:
NOTE: The IRC channel, #asuswrt,
has moved to the Libera IRC network
386.3 (xx-xxx-xxxx)
- NOTE: First time you boot into this version, you need to
either shift-reload the main index page, or clear
your browser cache.
- NEW: Added QR codes to the networkmap as well as the Guest
Network page, to allow easily connecting a mobile
device just by scanning the QR code.
The generated QR code can also be saved as a file
if you'd like to print it.
- UPDATED: chart.js to 2.9.4.
- UPDATED: tor to 0.4.5.8.
- UPDATED: nano to 5.7.
- UPDATED: curl to 7.76.1.
- UPDATED: dnsmasq to 2.85-openssl.
John Fitzgerald
From both Chrome and Firefox, link not working.
Server down?
octopus
Link working fine here.
John Fitzgerald
Thank you: @hervon and @octopus
Modem reboot solely didn't work but the subsequent router reboot did, which is very odd because I do automatic wee AM reboots.
Don't know if Windows 21H1 Release had anything to do with it.
askan7
Is this based on 3.0.0.4.386.42643 for AC86U that includes the fix for high cpu usage?
Zastoff
Smooth dirty update on RT-AX88u from 386.2_4 to 386.3_alpha1-gedfbfacce8
askan7
Read the change logs ?
I did, but doesn't say anything about that. I'm asking because the latest oficial version for ac86u includes that fix. I hate how slow v386 has been while transfering files from usb, with cpu maxed out.
John Fitzgerald
@RMerlin
Don't quote me but RMerlin mentioned in another post that ASUS had issues and stopped the flow.
If you look at Official Firmware, the AC68 has not had the update the others have had recently.
So my guess is it's not included but other components are being tested.
sbsnb
Found the reason:
nslookup onedrive.live.com
Server:  RT-AC88U.test.lan
Address:  192.168.1.1
Non-authoritative answer:
Address:  13.107.42.13
Aliases:  onedrive.live.com
          odc-web-geo.onedrive.akadns.net
          odc-web-brs.onedrive.akadns.net
          odwebpl.trafficmanager.net.l-0004.dc-msedge.net.l-0004.l-msedge.net
firewall stats search malware 13.107.42.13
Exact Matches;
| IP Address |       | | List |
13.107.42.13         | https://iplists.firehol.org/files/firehol_level3.netset
Skynet is blocking it.
John Fitzgerald
Found the reason:
Exact Matches;
Microsoft: The only link that wasn't working this morning, they must have pushed something. The Router Reboot cleared my issue, so Skynet isn't still blocking it.
For all I know my ISP updated Modem over-night, can't see logs anymore on new model.
octopus
Just updated my two routers and seems working just fine.
I can see Facebook is back...........
Thank you to new builds !
Screenshot 2021-05-20 at 17-47-35 ASUS Wireless Router RT-AX86U - Guest Network.png
Calkulin
Found the reason:
Exact Matches;
I have the same issue and results. Unbanned the IP and now can access it.
