[ 3004.388.5 alpha Build(s) ] Testing available build(s)
octopus
Part of the Furniture
As usual, no support is given on alpha programs.
3004.388.5 (xx-xxx-xxxx)
- UPDATED: OpenSSL to 1.1.1w.
- UPDATED: Curl to 8.4.0.
- UPDATED: OpenVPN to 2.6.6.
- CHANGED: Enable fast-io for OpenVPN servers using UDP, which
will speed up performance on some models.
- CHANGED: You can now directly enter an IPv6 address on the
Network Tools page as a target.
- CHANGED: Display tracked connections on the QoS/Classification
page even if QoS isn't set to Adaptive QoS.
- CHANGED: QOS/Classification page can now resolve local IPv6
addresses.
- FIXED: CIDR-formatted addresses were rejected on the Network Filter
page. Implemented temporary workaround.
All AX58U Running good so far!
Thank you
I've been including the fast-io command in my ASUS router OVPN server config for a long time. Is something different needed to make it work?
OneDrive link isn't working for me at the moment :(
Your link is only working for authenticated users - I can't access it without logging into my account first.
Use this official link instead:
Thank you, but no difference for me, it asks for authentication.
Try in an Incognito window. Works fine for me.
Can confirm the same (opening without issue) using "private window" and "private window with Tor" in Brave browser. And the same using Edge's "inPrivate window". Opens fine, not asked to log in.
I had no issues downloading from Mirror 1, w/FireFox. The Flash process was smooth on the AX86U. No log in required.
People are discussing the alpha build snapshots that are available on Onedrive, not the release images.
No problem both ways: you lost me on "snapshots". I reread all the posts and nothing sticks out?
Screenshot 2023-11-02 at 17-16-01 Test builds - OneDrive.pngScreenshot 2023-11-02 at 17-16-23 Test builds - OneDrive.png
Let's GO!
EDIT: Updated the APs last night. Did the 15-min reboot cycle. No issues so far. Will keep router on Release build for now.
LETS GO!
2*AX8U!
Even with that dang war I take risks to lose connectivity! ;)
Ax88U, Running just as should for 2h!
27 hrs and all good on my RT-AX88U.
Smooth sailing through the internet without a storm in the log (loglevel: warning - warning).
