Hi everyone!
I was a happy ASUS RT-AX86U owner until it got murdered by ASUS this spring in that infamous botched firmware update.
Since then I had the TP-Link AX50 - a decent, cheap-ish router that served my network (somewhat) OK.
But…and here’s the thing. I just upgraded from 200/20 Mbps to 1000/100 Mbps DOCSIS 3.1
Tested the WAN link speed on the ISPs modem itself - all good; speed is ~990ish down and 100 up.
However, the poor AX50 Is buckling under this speed. Max speed I get is ~530-550 Mbps.
Oh well…
question is simple; is AX86U still a good (ie. recommended) buy, should I wait for the Pro variant (any new rumors on that?) or is there something else you can recommend close/similar to AX86U? Or even better for the price (~€200-250).
thanks.
Oh well…
thanks.
