Enable Tor Connection via Putty commands / SSH
AppleAssassin
Hey guys,
First time posting on here because no where else on the internet has the answer for this.
Is there a way I can enable and disable the Tor service on the router via an SSH command line? I can connect to the router just fine but I can't find anywhere a command to enable the Tor service.
Any help would be much appreciated!
/jffs/home/tor-start
#!/bin/sh
local TOR_CMD="/usr/sbin/Tor -f /jffs/home/torrc"
local TOR_PID=$(/bin/echo $(/bin/ps w | /bin/grep -i "$TOR_CMD" | /bin/grep -v grep) | /usr/bin/cut -f1 -d' ')
if [ -z "$TOR_PID" ]; then
  /usr/bin/killall Tor tor
  /bin/sleep 1
  [ -d /var/lib/tor ] && /bin/rm -rf /var/lib/tor
  [ -d /jffs/tor ] && /bin/cp -a /jffs/tor /var/lib/.
  /bin/mkdir -p /var/log/tor
  /bin/mkdir -p /var/lib/tor
  /bin/mkdir -p /var/lib/tor/hidden_service
  /bin/mkdir -p /var/lib/tor/other_hidden_service
  /bin/chown -R tor:tor /var/log/tor /var/lib/tor
  /bin/chmod -R u=rwx,g-rwx,o-rwx /var/log/tor /var/lib/tor
  $TOR_CMD
fi
/jffs/home/tor-stop
#!/bin/sh
if [ -n "$TOR_PID" ]; then
  /bin/sleep 1
  source /jffs/home/tor-save
fi
/jffs/home/tor-save
#!/bin/sh
if [ -d /var/lib/tor ]; then
  if [ -f /entware/bin/rsync ]; then
    /entware/bin/rsync -axvi --checksum --no-W --no-times --inplace --stats --temp-dir=/tmp --log-file=/tmp/rsync.log /var/lib/tor /jffs/
  else
    /bin/cp -a /var/lib/tor /jffs/.
  fi
fi
/jffs/scripts/init-start
#!/bin/sh
# TODO: fix the passwd, group and shadow filenames to use the real ones
echo "tor:x:111:111:tor:/dev/null:/dev/null" >> /etc/p-a-s-s-w-d
echo "tor:x:111:" >> /etc/g-r-o-u-p
echo "tor::0:0:99999:7:0:0:" >> /etc/s-h-a-d-o-w
Last step is to configure your firewall as a TOR transparent proxy. It's very easy. Details here:
https://www.dd-wrt.com/wiki/index.php/Tor_on_R7000#Transparent_proxy
https://trac.torproject.org/projects/tor/wiki/doc/TransparentProxy
The Asuswrt firmware uses an outdated version of TOR. It's easy enough to upgrade, wtf Asus?
Ha! The CloudFlare catched me. So you must fix my init-start script (above) correct the filenames. You know what to do.
"Sorry, you have been blocked
You are unable to access snbforums.com
Why have I been blocked?
This website is using a security service to protect itself from online attacks. The action you just performed triggered the security solution. There are several actions that could trigger this block including submitting a certain word or phrase, a SQL command or malformed data.
What can I do to resolve this?
You can email the site owner to let them know you were blocked. Please include what you were doing when this page came up and the CloudFlare Ray ID found at the bottom of this page."
Hey guys,
nvram set Tor_enable=1
nvram commit
service restart_tor
Set it back to 0 to disable.
I can start the built-in(internal) TOR with mine a config the file?
I create /opt/etc/init.d/S35tor
#!/bin/sh
ENABLED=yes
PROCS=tor
ARGS="-f /opt/etc/tor/torrc"
PREARGS=""
DESC=$PROCS
PATH=/opt/sbin:/opt/bin:/opt/usr/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin
. /opt/etc/init.d/rc.func
But it does not work
 /opt/etc/init.d/S35tor start
 Starting tor...              failed.
I do not want to install the second torcc from Entware repo.
And internal TOR very few settings in a web the interface, only redirect all traffic clients/mac.
