I just bought the RT-AX86U Pro. I don't need the Pro features particularly but it was very good value on Amazon ($219.99 although it seems to have gone up since I ordered it but it's still cheaper than the non-Pro).
Problem is I need a 1 or 2 metre extension cable. Unfortunately, the power connector is not the same as on my other Asus routers which are 5.5mm x 2.1mm. This one, if I am measuring it correctly, seems to be 10mm x 5mm and 12v 3A. All the ones I can find seem to be 5.5mm x 2.1mm.
Any ideas where I can find a ready made extension cable? Is this an unusual size?
TIA
TIA
