Solved GT-AX6000 Aura RGB Merlin 3004.388.4_0
BeachGuy
I updated to Merlin 3004.388.4_0. I did a factory reset and initialized settings after flashing. I then configured including turn off LEDs in Admin and turn off Aura RGB in Dashboard but the ROG logo is still cycling through colors. I have rebooted many times and turned off/on.
Dashboard:
Aura RGB Enable
LEDs are currently disabled - please re-enable them to be able to use AuraRGB.
I figured it out. Have to disable Aura RGB in dashboard first and then disable LEDs in Admin
Thanks for all your help L&LD, especially recommending the GT-AX6000. It's so much more than my old RT-AC68U!
I do have the 68U meshed and it seems to be pushing good connection to several devices (PHY rate Tx/Rx ~1000Mbps). I know people recommend not mixing AX/AC but if it works it works?
