Help setup Aimesh RT-AX86U and two nodes RT-AC68U
ARamos
Hi all Asus Routers users,
Hi have three ASUS routers, two old RT-AC68U and a brand new RT-AX86U.
If I have one RT-AC68U as main router, using the mobile phone ASUS app "or ethernet cable" I'm able to find and add the other RT-AC68U and the new RT-AX86U as Aimesh nodes.
But I want the new router RT-AX86U to be the main router and the two RT-AC68U as Aimesh nodes.
It should be straight foward, I have repeated the sames steps on RT-AX86U, but the RT-AX86U doesn't find any of the RT-AC68U.
Does anyone have idea what I'm missing here?
Thanks,
ARamos
PS
If I go back to the original setup, I'm able to add again the the RT-AC68U and RT-AX86U both as Aimesh nodes without problems
bbunge
Part of the Furniture
Make sure you do a Hard Factory Reset on the nodes: https://www.asus.com/support/FAQ/1039074/
As the technology is different on the AX86U and the AC68U's, when setting up the AX86U do not use Dual Band Smart connect (use different SSID's for the 2.4 and 5 GHz bands).
Use only WPA2 and use 80 MHz bandwidth on the 5 GHz and 20 MHz on teh 2.4 GHz. Use fixed WIFI channels.
Connect the nodes to the router with Ethernet to the node WAN port to set up if needed.
Johno
What if the mesh nodes are connected via ethernet? Does the same apply to the WiFi settings (other than disabling smart connect)?
