I am using an RT-N56U with factory firmware (3.0.0.4.376.3754) as a secondary router wired via the WAN port to a LAN port on an RT-N66U running TomatoUSB-Shibby 131 which is connected to my ISP modem. The 56U is servicing a PC and a BluRay player on my second floor while the 66U services a PC via ethernet, a Raspberry Pi and a printer via wifi. As it is, the devices connected to the 56U have a double NAT and it seems I cannot maintain the connection of that router to the primary router/internet if I disable the NAT in the WAN>Internet Connection menu on the 56U. Also, the 66U and its connected devices cannot see or ping beyond the 56U (through the NAT) to its connected devices although the devices connected to the secondary router can see everything connected to the primary.
I would like to have the 56U provide wifi connection to the printer because it is much closer and has a more solid signal but at present, the devices on the 66U would not be able to use the printer.
BTW, I am constrained to using the factory firmware on the 56U because I am using Aterlo Nightshift software providing timeshifted Netflix video with a USB drive and that works only with Asus factory firmware.
