cybotic
Greetings! I'm am trying to enable both Alexa and IFTTT on my RT-AC5300 - It is failing to perform the link for Alexa & for IFTTT.
My setup is a Virgin Hub 3.0 in modem mode, and the RT-AC5300 is behind that.
I have enabled DDNS & web access, and these are functioning as expected - ie I can access the router from the internet.
Whatever Ive tried, I always get this error when attempting to link:
I have tried on different browsers. Ive disabled WEB/DDNS, rebooted, re-enabled .. Power cycled. etc
I also tried the linking procedure from a totally different computer on a different internet connection (logged into router, amazon, ifttt) rather than any part of it bieng on the LAN.
Nothing has helped.
Might be worth mentioning that when attempting to link, it will take several seconds before failing (with the ever-helpful msg as shown above)
I thought perhaps this might be related to https - as I get that cert warning when attempting to connect to the router via the web. Could this have something to do with it?
I tried to sort out the certificate thing - but my Asus MEnus differ from thos ein the docs, so Im not sure I was able to do this successfully. ANyway there is no mention of having to address this ib the ifttt/alexa linking docs.
Please advise - as I am totally out of Ideas here. Many thanks!
Nothing has helped.
