TP-Link TL-R480T+ Maximum Throughput?
coolspot
Hi all,
Anyone know how many mbps the TL-R480T+ can do?
I'm debating between the TL-R480T+ and the more expensive TL-ER6120.
Thanks.
This info is on TP-LINK Twain. But if I was you get the ER6120 it's your best bet from TP-LINK. I been using this for months and no issues. Of course I am using the matching managed gig switch with it. See my sign below for what I am using from TP-LINK.
Maximum Throughput on the router is excellent also if your on Windows 7 or 8 PC you can change your tcp.sys from default 10 to 350 (I still keep mine at 200) you'll need universal IP TCP patcher to change the limited value of half-open (incomplete outbound) default on Windows PC.
The TL-R480T+ doesn't have any throughput specs on TP-Link's site... they seem to only provide it for the ER6120 and more powerful routers.
Just wondering if the TL-R480T+ is sufficient for a 45mbps cable connection.
you did look at the AU or TW site also for TP-LINK? The USA site doesn't have all the info. They might not even have the info for their products.
Yes, that's why I posted on here hoping someone would know the true performance of the TL-R480T+...
