TUF-AX5400 ugly web GUI
Dutchmike64
Just picked up an Asus TUF-AX5400 router and although everything is fine, the web Gui is one of the most ugly ones i have ever seen. In fact it is so ugly that it is hard to use. I would much prefer the normal asus web Gui and if anyone knows how to get that installed i would be eternally grateful.
However i did make a slightly improved version of the web gui with an extension called Stylebot, i have included the file to use for the AX5400. Here are before and after images of the web interface : On the left the hideous Asus one and on the right the modified version that i made. With visible tabs, better colors, as little yellow as possible and no distracting background image.
As it is just a modification of the website that you see in the browser, there is no risk and no modification of the router.
Just install the Stylebot extension, go to "options" and import my JSON file. Do change the address is yours is different, my router is on 192.168.50.1 as you can see in the uploaded Json
You can find the json file here : CLICK
Dr Mono
You are not wrong… Gnuton is planning to switch it to vanilla Asus for his Merlin 388.
What’s your up time? I downgraded to 386 because of memory leak concerns. Some folks using 388 reported crashes after 10-12 days.
Dutchmike64
Great. i installed the latest 388 beta but that still has the TUF Gui. No experience yet with the uptime as i just had the router since a few days and have been tinkering around :)
Apart from the horrible GUI, everything else seems ok
BreakingDad
The ASUS gui in general is pretty dreadful, the Tuf is even worse. I've been a long time campaigner for a better layout. If I was smart enough I would write an addon, unfortunately i'm too thick.
Nice work on what you have achieved there anyway.
Dutchmike64
Updates some more and the new json file for download : CLICK
I would love to dive deeper in changing the interface, but when Gnuton will put the standard GUI in the 388 it will be much better.
Below the new style with select borders, white icons and some more changes :
