RMerlin
Asuswrt-Merlin dev
Asuswrt-Merlin 374.43 is now available for RT-N16/RT-N66/RT-AC66.
EDIT:
Asuswrt-Merlin 374.43_2 is now available for the RT-AC68U
EDIT2:
AC56U build is now also available.
The focus of this release was fixing bugs and polishing things here and there.
Changelog is here.
Downloads are here.
More details can be found in the complete changelog.
MD5 checksums:
EDIT:
EDIT2:
- Traffic Monitoring for PPPoE users has been fixed, and should now report correct figures.
- A couple of webui-related issues were resolved, such as the problems with the new Media Server page, SSIDs with single quotes in their names breaking the webui, and a few others.
- dnsmasq now returns an empty string when queried for a WPAD proxy URL, which resolves log noise for broken clients such as Windows 7. Note that if you were using a custom dnsmasq.conf to provide a valid WPAD URL, you will need to change your config to use a Postconf script instead, to modify the default 252 option entry in dnsmasq.conf.
- A few component updates - miniupnpd and openssl were both updated to their latest versions. Additionally, a few additional ASM patches were backported from openssl 1.0.2, improving SHA performance for ARM-based routers.
- Guest clients were able to acess LAN devices when they weren't supposed to
- And a few other fixes, listed in the changelog.
- One new feature did trickle down into this release - you can now force a DDNS refresh after a configurable number of days.
Changelog is here.
Downloads are here.
MD5 checksums:
6c0f3e96c30896b06de74e47a22b2338 RT-AC66U_3.0.0.4_374.43_0.trx
c950755cdbc5f8d1078d2b8d4f105ab2 RT-N16_3.0.0.4_374.43_0.trx
78ebdd8b4c48fcfc7bef63111ad7ec4e RT-N66U_3.0.0.4_374.43_0.trx
aa8091c9ddeb2f74e3f8a61e3fd12e18 RT-AC68U_3.0.0.4_374.43_2.trx
f357623534a2fa4ad9d4d4195a3139c3 RT-AC56U_3.0.0.4_374.43_2.trx
